Go Back   Rolex Forums - Rolex Watch Forum > Miscellaneous Forums > Pens & Writing Instruments
Old 21 December 2020, 05:30 AM   #1
Reluctantly
Ball diameter on Montblanc Rollerball (Best size for signatures)
The information on Montblanc's website is very confusing and seems to suggest the Broad refill on LeGrand is 1mm but the Broad on the Classique is 1.4mm. I understand that the Broad was only available for the LeGrand. From the website:
"Refill Rollerball" and "Refill Fineliner": suit the Meisterstück Classique , Starwalker, Bohème, Muses Editions, Montblanc M, Great Characters, Limited Editions.
F stands for Fine, ball diameter 0,5 mm
M stands for Medium, ball diameter 1,0 mm
B stands for Broad, ball diameter 1,4 mm
"Refill Rollerball LeGrand" and "Refill Fineliner LeGrand": suit the Meisterstück LeGrand Rollerball.
F stands for Fine, ball diameter 0,6 mm (Rollerball only)
M stands for Medium, ball diameter 0,7 mm (Rollerball only)
B stands for Broad, ball diameter 1,0 mm (Rollerball only)
Fineliner EF stands for Extra Fine, diameter of felt tip 0,55 mm
M stands for Medium, diameter of felt tip 0,8 mm
B stand for Broad, diameter of felt tip 1,0 mm
Can someone confirm what the ball diameter is on the LeGrand refills? I assume the info on the Montblanc website is wrong and that the Broad on the LeGrand refill is not the same as the Medium on the Classique!
Reluctantly is offline   Reply With Quote
Old 21 December 2020, 10:59 AM   #2
Reluctantly
I have a Meisterstuck classique that I use for notes, I use a medium-size refill for that. I was interested in getting a LeGrand Meisterstuck for signatures and for that I want a broader line than the one I'm used to on my classique. If the LeGrand broad is the same as the classique medium then that's not wide enough.
Bernard Watches
Copyright ©2004-2024, The Rolex Forums. All Rights Reserved.
